- Joined
- 27 Jan 2008
- Messages
- 28,917
- Reaction score
- 3,538
- Location
- Country
typical lamp over a shower, advert does not give IP rating, and says fitted with a MR16 12 volt 3 watt DC bulb, finding DC bulbs not easy, Bedazzled specialise in them and yes you can get a MR16 LED bulb
i.e. has a multifaceted reflector, although the one shown in the picture of the fan does not look like a MR16 to me, but the options on the site for DC bulbs normally 10 to 30 volt DC only shows 6 and one looks like this
and one must ask if this is suitable for a bathroom? The side view does not seem to show any glass over the LED chips, and it seems unlikely that bulb is IPX4 or even IPXXB or IP2X.I have seen many bathrooms where the roof is sloped, yes the national standard sets a minimum floor to ceiling height of 2.3m for at least 75% of the gross internal area. The London Plan takes this a step further by setting a minimum ceiling height of 2.5m. An explicit standard for ceiling height was removed from the Building Regulations when they were simplified in 1985. However the sloping roof is often lit with down lighters, so although over 2.25m is possible for 75% of the ceiling, we may have bulbs below that height, with a tungsten bulb the glass was clearly water proof, but with LED lights the same can't be said.
So it would seem you can only fit 2" down lights where the ceiling is over 2.25m as the bulbs have no IP rating.
What does the team think?
