- Joined
- 8 May 2017
- Messages
- 10,639
- Reaction score
- 2,868
- Country
Cut a section of the pipe out ,inspect the inside and tell us the result.
He did explain it, I think the earth bonding comes in with the main electrical wires from outside the house on the electricity board side of things. It’s all modern cabling. Way above my head, but he’s a qualified electrician.In simple terms the "Earth" in the consumer unit ( Fuse box ) is often connected to the incoming Neutral in the supply cable. The Neutral should be at the same potential as the Ground but in reality it can be several volts different from Ground potential.
That is rediculous and suggests your "electrician" lacks the basic knowledge necessary to work on electrics. You need a electrician to check the installation for safety of people in the house.
Will do, just going through my options at the mo as to whether trycopper again, or use plastic.Cut a section of the pipe out ,inspect the inside and tell us the result.
I appreciate that reply, but it is well beyond my comprehension
There is no physical earthing strip to my MCB, the electrician said it’s not needed, and the only electrical connection to the copper would be through the Worcester oil fired combi boiler.
My multimeter only has 600v and 200v on the AC side of things, but there is no voltage at all showing on either.A simple check....
Do you have access to a multi-meter?
Set it on an ac voltage range, beginning on the highest voltage range, one probe on the earth pin of a socket, the other on your copper pipe. Adjust the voltage range down, to see if there is a voltage potential between the two, then report back here, with the result. There should be no voltage difference, between them.
Earth pins in socket are likely to be connected via bonding to the pipework so will be at the same potential. A more informative measurement would be that between the concrete and the pipe. Damp concrete can be electrically conductive. There could be moisture in the concrete from the door ( or window ? ) that can be seen above the pipe
The concrete in the kitchen was bone dry for months before the brand new copper pipe went in. It’s on a brand new extension, with all relevant dampproofing, etc.
However, the pin hole leak that I found last month in the vertical pipe in the garage was leaking 1.5 litres a day over many, many months. It was hidden by foam insulation. That pipe goes down the garage wall, through the blockwork wall, and continues as the cold water tap feed pipe you see affected in the kitchen. I wonder if some of that water has transferred through the wall via the insulation to the insulation in the kitchen. I wonder if the two are linked ?? It’s odd that the hot water pipe next to it is not affected ??![]()
Did you cut out a section of pipe that leaked in garage ,if so did you look inside it ?
I can absolutely assure you there has always been pin hole corrosion on copper tube.I’ve never had any issues with copper pipe in the twenty three years I’ve been using it in this house. Has there been issues with the standard of copper pipe recently ??
It is guaranteed for 25 year but its almost a waste of time
