Is it a case that the older pipe is thicker ? Or is the new stuff somehow inferior copperMy copper is around 40 years, maybe on borrowed time..
I have never given it a thought that a new length of pipe could have pinholes in it. From now on I will be examining each length very carefully.
But how other than by eye, cap the end and attach a hose pipe to the other and try and get some pressure in there ?
But then the OP problems were not evident on commission.
Copper pipe corrosion ,internally, forms the series of small lumps that you see inside the pipe. This is commonly known as "pitting". The exact cause of pitting is largely unknown,although many theories exist ,which include (to name just a few), water quality and the chemicals present in potable water with varying pH levels, residual flux left in pipework, electrolytic charges present, poor quality copper tube with high levels of carbon content. Much research has been done on the issue , particularly in America, (where in certain areas the problem is rife ,and pin hole leaks appearing within months of installation ). Unfortunately ,to the best of my knowledge,no single factor has been identified as the root cause.
Yeah, I’m up in Hartlepool. Our water is very hard. And I’ve got a combimate fitted.I work mostly in a area where the water is described as aggressively hard .
See pinholes in copper fairly regularly properties with water softeners seem to get way less.
Copper cylinders don't last long either we now use stainless steel replacement cylinders.
