I have a McAlpine flexible connector going from the toilet into the cast iron stack. The cast iron is approx 3.5” internal diameter and has a short 200mm horizontal sloping run before joining the building's main vertical pipe.
The flexi connector is like the one pictured, except mine does not have the fins on the outlet side - it's smooth. It doesn't insert very far into the cast iron collar (if that's the right term. Bell?), no wet sealant has been used and it looks like water is tracking back up the plastic and rusting the collar. What is the best way to fix this?
1. Extend the plastic connector's outlet side so it inserts into the cast iron a bit further, and use a wet sealant (what type?).
Or
2. Replace the flexible connector with a finned one.
3. Something else?
Or
3. Something else?
