integrated fridge door retainer
30 Mar 2015
Not sure what this is called, but the bit that holds my fridge door to the kitchen door is broken. I can see that it needs to slide on to the fitting that is on the fridge door. This part is fine.
Any suggestions on where I can a replacement for the broken piece and will it be compatible with the bit that is on the door please?
Thanks in advance.
it looks to me like they work the same way. It is not really a hinge, it is a puller.
if you can find a makers name or the supplier you might be able to track down the original.
