outside Socket
24 Apr 2008
UK, Wittering, West Sussex
I'm getting one of these Black waterproof outside sockets from TLC later this week
I would like all black and no neon, cant find that , although maybe a bit of black gaffa tape on the inside of the lid , which i have - not sure if that will be an annoying glow near the house
I cant find a BLACK T&E compression gland - so will use this
and the locking ring
side entry on the box
which may then go up to the wall , and silicone
But just trying to find a bit of trunking or conduit if i have to go a bit further away from the side entry
I have white already but not 100% sure on best connectors, which other half said will use chalk paint on
any advice as 100's of items on website and NOT sure what to look for to filter
Likely you can remove the neon wires to prevent them working.
Perhaps you could replace the socket.
Can you not feed the cable to the back of the socket from inside the house?
no not able to which would be idea , I will have another look around and see i fi can repostion somehow - that was my first thought , but the bracket they are fitting will be in the way .
Had not crossed my mind - got a few of those i recently had a 10 pack - and just a normal double socket
thanks
the smoked plastic lid muffles the light, but you could put black tape or black paint on the inside of the lid to hide it.
I used one from screwfix, and inside it was a standard socket, so easy to swap. The problem was gland hole 22 mm not 20 mm, as to gland for twin and earth why? Twin and earth not rated for outside use.
@ericmark
that was why I saying
BUT BLACK
the gland i was hoping will be right up against the wall , but cannot find a compression for T&E
BUT I found that screwfix & toolstation also have a black trunking /conduit glands
DETA TTE MALE CONDUIT ADAPTORS 20MM BLACK 2 PACK (351VT)
DETA TTE FEMALE CONDUIT ADAPTORS 20MM BLACK 2 PACK (907VT)
DETA TTE ROUND UPVC BLACK CONDUIT 20MM X 2M (712VT)
20mm Heavy Duty Round PVC Conduit 2m Black by Profix Product Code: 47063
PVC Conduit Male Adaptor 20mm Black by Profix Product Code: 41358
Yeah, If you are just comming out side wall and into the side of the socket, I'd just use a bit of black PVC conduit, drill the hole on the outside wall 20mm at least a little way into the brick and the conduit will slot into it a little way. If its only a tiny distance you are going (like 70MMish or less or so from the wall) As in, you are putting it as close as possible, but need to space it off a bit for the lid to open - then just align the hole in the wall with the entry on the socket box and have it going straight across. If you are going a reasonable distance, you will will need saddles and aim for the *edge* of the hole to be approx 1/8" off the wall you are fixing saddles into, then you'll need a spring and pull a set to get into the socket.
