Without full details it would be anybody's guess... With some of the hair-brained schemes that are put forth on here!
Sorry I didn't know you were still talking. I've got a bit of room to play with and the box will be lower than the boiler I should think so I assume that will add distance.Maybe the OP can come back on and clarify what he meant?
Also does anyone know if this needs a membrane that goes behind the box and tucks under the lintel or a dpc above the lintel with weep holes? Cheers
Like this.
Have another look. I was editing it. it kept rotating the picture 90 degrees.Just add the image to this thread using the attach files button.
Your link above doesn't work (for me at least!)
Thanks for looking.
Can you add a few more vertical measurements? Looks fine so far but verts are missing... Boiler vs meter height from ground level.
Yes, no problem.So am I right in thinking the boiler could go directly above the meter if needs be? Cheers.
I had a better measure up today. Not quite as wide as I thought but lots of height due to outside ground being low. So the box can be low and still above dpc. So am I right in thinking the boiler could go directly above the meter if needs be? Cheers.View attachment 347074
Yes, no problem.
You're fine mate.
