Kitchen design
You seem to have a lot of cupboards.
Get pan drawers.
Why are you getting little 600 units?
@JohnD Thanks for the suggestion... Main reason on the 600's was trying to keep things lined up etc, but that's proving more challenging :D
Edit: Also, on the last 2 designs, there are 3 lots of pan drawers (1000mm and 2x 600mm) on the left run...
You've got a roundabout! (I hate islands). Cooking at the hob and need something out the fridge - round and round!
At risk of losing space I would not have that misalignment :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
No, seriously, it only matters to nutters like me.
I too would want at least the 2 sides to finish level. If not the island too.
Too big an area not to have an island though
Yeh, I can't see us not having an island... I'm just struggling to get a "longer" counter space...
This one atleast finishes close to level across the bottom... Only allows for 680mm between edge of island and oven/fridge though...
Or one keeping fridge, freezer, hob and ovens on one side...
Feels a bit lop-sided to me though...
I visited the showroom and DIY kitchens (the one you are using?) and you see ideas you had not thought of...or are you buying just from the site without a visit?
So I did look at visiting the DIY Kitchens showroom, but it's a 3.5 hour drive each way.... Though if it's worth the trip then maybe we'll look at it again...
they have a location in the London area now. I visited the showroom on 3 occasions for clarification and technical support and to look at ideas. It is the best showroom you will ever visit. What we ended up with was nothing like the design we had envisaged in both layout and colour. I figured when I'm spending that much money on something that I expect to last for at least 20 years, it would be stupid not to visit.
If you can fit them in with the ceiling height, I would always use 'tall' wall units, 900mm high. Storage is always a premium and the shorter ones tend to just be used as a dumping area and collect dust and grease.
Personally, I think that a sink in an island is a terrible idea. Aesthetically - dirty dishes on display in the centre of your lovely new fancy kitchen. I know that sinks in islands seem to be a common design theme, so I may be in a minority here
The other thing I would worry about is the discharge of dirty water into any drainage - I've seen the state of my waste pipe - how on earth can an underground waste pipe be kept clean enough to remain efficient?
Regards
Tet
I would avoid having hob in island , those downdraft extractors are feeble . Have island one unbroken worktop . Design looks a little disjointed .
I sincerely hope that you are incorrect. We went to a siemens downdraft demo in Central London and were very impressed with its extractive abilities. The Neff equivalent is an almost identical twin, made in the same factory
I can't comment on it in use yet, as we are about a month away from it being installed
Regards
Tet
It really depends whether you are actually a cook or not. The problem isn't so much the ability to extract- I'm sure the demonstrations are impressive, it's what happens in the extraction trunking. A long trunking going downwards extracting lots of water vapour and fatty smoke and vapour - what do you think is going to happen? If you are a keen cook, your extraction wants to be on an outside wall with the shortest trunking possible, otherwise condensation within the trunking combined with all the fatty deposits are not a good prospect for long term efficiency!
You hope the filtration will capture everything. You hope...
Why not delete the island, consider a G shaped design with everything around the walls and a sticky-out bar rather than two openings either side of the island. You then have an open work area with an unrestricted work triangle between cooker, fridge and sink. But there again, I just hate islands!!
Regards
Tet
I've always installed 50mm pipes for kitchen sinks.
If going underground like on an island, 4 inch pipe if possible, connected to waste via the shortest route.
Never had a blockage.
