I am happy to provide the sparky brand new retail parts from online retails by shopping around for best price and take responsibilty if any of the new part is faulty.You are entitled to want a good quality brand. Nobody will stop that.
A consumer unit is not a single part - it's a collection of parts specific to a particular installation.But with Sparky work it seems a bit more complex as none will touch the work and want to quote for a complete project.
So these RCBO at £14 each should not be used??You are also attempting to get 'deals' on Hager RCBOs, which are already some of the cheapest available at about £14 each.
Why would you think that?So these RCBO at £14 each should not be used??
I am a bit lost here...are you saying the items this shop selling is junk and should let sparky purchase from a expensive shop??Why would you think that?
The point is that as they are already some of the cheapest, your searching about for savings will in reality save next to nothing, but is very likely to cause a pile of wasted time and hassle for whoever is unfortunate enough to be installing it.
Got it in one.Thing is proper sparks fit the same brand and almost certainly carry a box of spares / extra parts in their vans (I always do)
No.I am a bit lost here...are you saying the items this shop selling is junk and should let sparky purchase from a expensive shop??
Not even close. Properly inspecting and testing 8 circuits, fixing problems found and then installing a consumer unit and then doing the required tests afterwards is a full days work at least, and could easily be more depending on the condition of the installation.Maybe I was naive thinking about 3 hours of sparky time would cover it since there are only 8 MCB
So could pass £1k for updating this to 18th edition. So even more reason to scrap the idea...if it aint broke then nothing to fix.Not even close. Properly inspecting and testing 8 circuits, fixing problems found and then installing a consumer unit and then doing the required tests afterwards is a full days work at least, and could easily be more depending on the condition of the installation.
