Probably a daft question: bicycle sized dust caps on car wheels?
JP_
17 May 2012
A week ago I had a new tyre fitted.
Was driving for a week before noticing that the dust cap was missing.
Having no spare, I took one from a bicycle in the shed.
Overnight I lost about 10psi (31 down to 20).
Have repumped, and loosley put the cap back on. Hoping that the cap was just too small, and allowing a tiny bit of air to be released.
Does this sound likely? I will probably find out when I get out of work to go home ...
Standard bike valve dust caps are the same as cars (Schrader). The presta valve caps from a bike wouldn’t fit on a car valve. Tighten it up - if your car valve is leaking, the cap acts as a secondary seal.
But hang on. Time got away with me. Statement says I got the new tyre on the 5th July.
So I was driving it with no cap for 18 days OK, and then in less than a day of putting that cap on (yesterday afternoon) it loses air. Must be the small cap pushing the pin down, surely?
Sounds like a faulty valve to me, dust cap is just that, to keep dirt out.
Take it back to the garage,
Just say it is loosing pressure.
Correlation does not mean causation.
As a dust cap is domed, I would say it is nigh-on impossible for it to press on the (Schrader) valve pin.
you say fitted on the 5th July !
when Labour took power, and you're surprised its not working properly
seriously though, have you got a picture of the valv and the valve cap ? just in case you are trying to fit a presta cap on a shrader valve
Neither cap would fit on the other.
No, but with a lot of perseverance you may get a presta inside a shrader, and that would cause your tyre to go flat - never underestimate what can happen
Yeah anything is possible but you'd have to be a right dimbo to do that though.
Correct the tyre pressure. Keep the valve cap off. Check pressure in a week .
Or go back to fitters and just say it keeps losing pressure
swap the suspect cap to a different wheel, and put the known correct one on your suspect wheel.
Commercial dust caps are good as they contain an O ring which makes for a secondary seal, only downside is that they are usually yellow.
Have you tried the old trick of applying spittle to the valve to show up any leakage?
