This is slightly odd in that I only want to replace the metal box and not any of the MCBs or tails which are all fine. The consumer box which is metal is showing signs of failure. In that one of the cover screw lugs has decided to part way with the side of the box
The box is fully isolated by a double pole switch and so can be safely worked on. I am an ex electrician now retired so comfortable with doing the work. I would also take the opportunity to mount the box on a osb board with wall spacers rather than the wall.
All this I could do with my eyes closed. I don’t want the expense of getting this tested and certified as to me it’s totally ridiculous given what I am doing. If I can’t do it then I’ll work out a solution to the broken lug but I thought I would ask here
