- Joined
- 22 Aug 2024
- Messages
- 10
- Reaction score
- 0
- Country
Hello,
I am buying a new entire heating/hot water system for a 1920's 4 bedroom, 2 bathroom house which will also be fitted with solid wall insulation. I have radiators, I don't have underfloor heating and I would like an indirect unvented cylinder for mains pressure hot water for the showers.
What I think I know (please correct if I'm misguided):
- 150L tank should be big enough - most of the time just 2 people in the house
- ~15 radiators - 20kw gas system boiler should be over sized
- I'm probably going to want to "heat on demand" so using a room thermometer is probably the way forward rather than low and slow weather compensation with otuside thermometer
- I need to set the unvented tank temp to 60 degrees
- S looks like most standard plumbing to not be overly complex. My boiler when heating my house should modulate using the thermostat and be fairly efficient
- When my tank is in use my boiler controller will need to request hotter water (60 degrees) so override the modulation of the thermostat - this is called hot water priority?
- If I oversize my radiators even if heating to 60 degrees the return temp of 15 radiators in my cold house is likely to be ~ 40 degrees so good for condensation anyway?
What I've no clue on:
- How the unvented tank actually works
- It has an electric heater in it, I'd rather only use this as backup by default I assume it's generally off?
- When someone turns on the tap it has a sensor which will tell the boiler controller to open the valve and start producing more hot water?
- The boiler controller has a timer to heat the tank at certain times of the day? Or does it have a minimum temp setting and when the thermometer on the tank drops it will heat it back up?
- How direct hot water will work with modulation on an S plan?
- Is it really worth having automated TRV's like Tados in a house like mine or if it's better just balance the system oversize the radiators and pray for efficiency gains?
What I would really appreciate some advice with:
- I haven't been able to talk to my contractors plumber yet, but I've been told he can fit anything but is a valiant installer so will get an extended warranty if I go valiant.
I have therefore chosen a Valiant ecotec plus 620 with a Gledhill ES Indirect Stainless 150L Unvented Cylinder. I don't know what comes with these items and whether I need to purchase controls and/or wifi control seperately
At this point I could change everything. I just want to be environmentally friendly, have a low gas bill while hopefully being warm with a nice shower pressure
Appreciate you taking the time to read the post
Thanks,
Adam
Thanks,
Adam
