CDA washer dryer will not start
28 Aug 2024
i have a problem with a CDA washer dryer model numberWD602 intigrated. What is happening is when i press the start button on any programme the pump starts and then the motor gives an instant start and then stops.It only revolves a few revs.
I have had the door switch out and all looks good,brushes out and they are clean and have plenty of life. Commutator cleaned with glassfiber pen.
Circuit boards are clean and not burned anywhere. Most connectors off and back on but the fault remains I saw a code of F09 but that isnt recognised in any fault charts.
It dates from 2007 but has only had maybe 50 wash cycles in its life its like new. Any help would be appreciated.
Does the motor take off as though it's trying to go flat out.
I once had a Meile that did that. Regardless of the selected wash it went into an immediate full spin. The main PCB had to be replaced. It was an expensive component, but I managed to get it replaced for free. From memory, the PCB, plus fitting would have been a third of the initial cost of the unit- it was less than 3 years old at the time.
Yes it does .It looks like its a scrap machine I think thanks for your input
