All that is wired to do is shut down the flow to the cylinder when the cylinder stat is satisfied- if it isn't back to the wiring centre then there will be no switching to/from the boiler/programmer. So it'll just be power in to the junction box, out to the stat and then a switched live out to the 2 port to activate. No reason it can't be wired to the rest of the system
Putting in a wireless programmer won't fix any of that, it will only control the CH, the cylinder stat and 2 port need to be interconnected hence the cabling required.
It is an installation standard that an interlock is provided and that would require all that to be cabled up properly, he hasn't done that basic requirement either. Are you down south, if so then that install would also fall under the boiler plus regulations, which also covers the interlock requirement.
He really has tried to pull a fast one - Bodgeit and Dash Heating Services - by the sounds of it.
