- Joined
- 30 Aug 2024
- Messages
- 3
- Reaction score
- 0
- Country
I'm trying to fit wall bars (looks a bit like a ladder and has a pull up bar attached) in a room. Unfortunately my knowledge of fixings/walls is a bit lacking and I'm looking for some advice on how best not to have the bars pull out of the wall in use.
Looking at other posts, I think this dewalt aerated concrete anchors (like these https://www.screwfix.com/p/dewalt-aerated-concrete-anchor-nylon-70mm-40-pack/749ht) are what I need, does that sound right? The wall bars have 12 fixing holes for bolting to the wall (4 at the top, 4 middle and 4 low).
As a kind of belt and braces solution I thought I could get a couple of fence braces and bolt one end to the floor (that's concrete under laminate) and the other end to the wall bars about ¾ the way up the upright.
Some more info on the wall etc:
The internal wall is painted plaster, behind which is…something. When I drill through I get a grey powdery material that is about 18cm deep, about 4cm after that I hit the external brick wall (it’s an external wall on an extension). Drilling through the grey stuff is not super hard, certainly don't need the hammer setting on the drill to get through it. The wall is on an extension that was built sometime around 25 years ago.
