If you want a copy you will have to contact the electrician; not the other bodies.
Not clear to me why the existing 13A socket in your garage isn't safe to charge from.1. In line charging would require some wiring changes to make it safe and unlikely to get super cheap tariff for EV charging. This will be expensive and approach the cost of a dedicated charger install.
I've never heard it called an "in-line charger". "Granny cable" is the usual jargon. And as other pedants like to point out, the charger is in the car. Also they usually come with the car, so I wouldn't anticipate needing to buy one separately.
Where are you getting 30hrs at 3kW from? That would imply a total charge of 90kWh...they never made a Zoe with a 90kWh battery. Charging is obviously not 100% efficient, but it's not that bad
A quick google suggests a Zoe has a 52kWh battery so you'd be looking at around 23h of charging from 0-100% [which you wouldn't want to do].
Very few EVs are supplied with portable EVSEs (granny leads) anymore. Mode 2 charging isn't generally recommended as it can burn out the socket-outlet.Not clear to me why the existing 13A socket in your garage isn't safe to charge from.
as they have no control other than turning off whole house, street, or area.
the bottom two pins are for DC so only used with fast chargers, the 7 pins often 2 pins missing
are not all the same, the protection is the main variation, 6 mA DC, loss of PEN, RCD, may or may not be included, so prices vary. Some
will allow you to swap and change the plug. Clearly using even a 16 amp commando plug will increase charge rate by 1/3 so I would be at least looking at a 16 amp socket, butSo convert to amp hour at 230 volt so 226 amps for one hour, although likely 1.5 hours is fastest it can charge at, or 7 hours at 32 amp, 14 hours at 16 amp, or 17 hours at 13 amp, or 22.5 hours at 10 amp. But this is looking at a dead battery to start with, so this will not happen. But what we want is for it to charge within the off peak available.A quick google suggests a Zoe has a 52kWh battery
You're not suggesting our beloved BS1363 sockes are not fit for purpose, are you?Very few EVs are supplied with portable EVSEs (granny leads) anymore. Mode 2 charging isn't generally recommended as it can burn out the socket-outlet.
That's not the purpose for which they were designed in fairness.You're not suggesting our beloved BS1363 sockes are not fit for purpose, are you?
They have been altered since they first came out, the line pin on the plug, is now reduced in size so insulation can be put on the pin, so it does not sink the heat as well as it use to, the cable used to wire them reduced from 2.7 mm² to 2.5 mm² and the brown and black bakelite replaced with lighter colours less able to radiate the heat, and also less able to stand the heat.You're not suggesting our beloved BS1363 sockes are not fit for purpose, are you?
Forgive me for being ignorant; what exactly were BS1363 connectors designed for if it wasn't for powering 13A loads?That's not the purpose for which they were designed in fairness.
Not for long durations.Forgive me for being ignorant; what exactly were BS1363 connectors designed for if it wasn't for powering 13A loads?
With respect, my experience of BS1363 connectors has always been that they have never matched the performance of BS546 and is precisely the reason that public entertainment clung onto them rather than moving to the 'newer plugs'. Personally I don't believe the different colours or reduction of metal has made much, if any, difference. I believe the major failing has been the reduction of quality due to costsaving, such as MK outsourcing to some 'unpredictable' manufacturing service.They have been altered since they first came out, the line pin on the plug, is now reduced in size so insulation can be put on the pin, so it does not sink the heat as well as it use to, the cable used to wire them reduced from 2.7 mm² to 2.5 mm² and the brown and black bakelite replaced with lighter colours less able to radiate the heat, and also less able to stand the heat.
Yes they were designed we are told to allow homes to be electrically heated, however they must have had a large cheek to put their tongue in, dad's old post war house, 6 rooms, so if a 3 kW fire in each room, that's 78 amps and main fuse 60 amp. And only one ring final which had a 30 amp fuse. So 30/6=5 amp per room, so 1200 watt per room, with remember no double glazing, steel window frames, and no thermostatic control. House built 1954 only 4 rooms had fire places, master bedroom, living room and dinning room, and aga in the kitchen, which in winter was never allowed to go out, one as only way to get a cup of tea (coffee unheard of then) and darn cold if it when out.
The BS 1363 socket is really good, but not really fit any more for what it is claimed it was designed for.
I'd love to know where that is stated in the BS, I'll bet you can't find it.Not for long durations.
