What temp/humidity does water condensate in loft?
7 Apr 2023
I am going to run a dehumidifier in the loft when the weather is at its coldest and would like to know if anyone knows the science that would help me set the humidity detection to the right amount. Example; operate to dehumidify to 60% and operate when 5 degrees celsius or lower. I want to reduce the moisture enough so that water doesn't drip from roof underlay.
Background
I know creating more vents is the best thing to do; this a temporary quick fix.
When it's extremely cold, condensation drips from the underlay (it's 50 years old and not breathable) creating huge puddles
I would only run humidifier when it's very cold (perhaps 0/1 degree outside)
I have maxed out the overrun extraction times on the powerful centrifugal inline extraction fans that are pretty much above the showers to remove as much everyday moisture as possible
Condensation forms at a range of temperatures….it’s the result of warm moist air hitting a cold surface.
So it’s going to happen when the external temperature is low, say during a chilly night and morning.
When and how it happens might depend on whether it’s a ventilation issue between roof space and outside or an insulation / air tightness issue between house and roof space. If you have warm moist air getting in from bathrooms or bedrooms that might be the cause.
Does your loft have plenty of loft roll insulation….sometimes it’s pushed into the eves and blocking soffit / fascia vents
I don't think my style of pitched room created vents through eaves! There is lots of insulation but it is not near the gap where eaves would be. I can try sealing off the 4 downlights in bathroom perhaps but the overall moisture from the whole will still reach the loft eventually....
You are mistaken .
This is how you work it out. From the table above say take a temp of 20 degrees. The saturated vapour pressure @20 degrees is 17.54. If the relative humidity in your loft at 20 degrees is 50%, then the vapour pressure is 17.54 * 50% = 8.77
8.77 is the saturated vapour pressure of air at about 9 degrees, so any surface colder than that will attract condensation if still air at 20degrees/50%RH comes in to contact with it and has an opportunity to cool to 9 degrees.
However, that air at 20 degrees/50% RH has the capacity to absorb more water, so if it is moving over a wet surface without an opportunity to cool, it will evaporate water, increasing its humidity.
By extracting moisture, a dehumidifier decreases the RH of the surrounding air, and hence lowers the dew point.
Background
You haven’t said why?
You are mistaken .
Please see photos below. There's an integrated gutter. The overlapping part on the exterior is closed with panels. Where could the eaves be on this style of roof (70s house).
I have added a photo on a post above. I have added the insulation you now see there, but it has not been stuffed into any eaves (wish I could find eaves but I don't think they exist in my roof?
With regards to keep moisture out I feel that is a losing battle because a lot of moisture will find its way up eventually...
Background
Google relative humidity. Air can carry different amounts of water depending on the air temperature, so air at 20 degrees at 50 RH will be carrying a lot more water than air at 5 degrees, 50% RH.
Your problem will be warm humid air from the house escaping into the loft when it's cold and then condensing on the cold felt. A dehumidifer in the loft won't help as it won't dehumidify the air fast enough. You need to significantly increase the ventilation in the loft or reduce the leakage of warm humid air into the loft.
Some of the wool insulation under the felt has split open so perhaps moisture more easily hits the cold felt; if I seal them back up might that help by keeping most of the roof area warmer internally and therefore less condensation?
You need to stop the humid air getting into the loft if you don't want to do ventilation. You could do that by improving the ventilation in the bathroom (opening a window as well as running the fan. A big fan won't do much if the air tries to remove doesn't get replaced), generating less water vapour in the house (do you dry washing on radiators, boil lots of water in open pans without extraction etc), or you could try running the dehumidifier inside the house rather than in the loft so that the air that leaks into the loft isn't carry as much water.
