Trailer wheel bearings - why?
30 Dec 2018
Up North
OK, I've been buyng a second-hand little trailer. Many of the ads say 'new bearings fitted', or similar. A couple of friends have also reported breaking down, whilst towing a trailer, due to bearing failure. I've towed caravans for decades, never had a bearing failure, so what is it about small trailers, that they suffer such frequent wheel bearing failures, with such irregular use?
Yes, I have just bought one, and yes, wheel bearings were checked, and absolutely fine..
I've worked on several heavy duty trailers, and on each one the water ingress to the brakes has a detrimental effect of everything inside the drum.
There is so little done to prevent this.
The big stuff often has taper roller bearings, which get little attention, if any at all.
Overloading is sure to play a large part of bearing failure.
John :)
and cheap inadequate suspension
Identical suspension system, from the same manufacturer, Alko, as 90% of modern caravans. A torsion bar design, in a rubber filled square tube. All I can imagine, as the difference, is that caravans tend to be checked and serviced more regularly, whereas small trailers are just used, never maintained. Only takes a second to lift one side up, they don't need a jack, just give the wheel a spin and listen.
With a caravan Harry, I guess there has to be a maximum weight - although who knows what the owner will pack in.
With trailers, anything goes so low long as the thing will actually move.....I’ve seen bent chassis and collapsed ramps etc.
It’s the weight that kills the bearings!
Regards
John
There's no MOT requirement for trailers. I suspect that has a lot to do with it. Plus, of course, many are still on taper roller bearings, which, when that was commonly used on cars, never delivered the sort of life that modern, double-row spherical bearing packs give today. I've done a lot of boat towing, back in the day. They're a special case, of course, particularly when launching in seawater, but I can go on eBay and buy a set of taper rollers for my current trailer for £8. They'e absolutely awful, of course! I also think that availability of ultra-cheap bearings is a factor.
Even if the wheel bearings kit were checked and are in good condition, trailers, especially small ones, can still experience failures if the trailer is overloaded, improperly maintained, or subjected to environmental factors like water or dirt. To prevent these failures, it's essential to regularly inspect and maintain the bearings, ensure proper loading, and be mindful of overloading. Replacing bearings with good quality, high-performance ones and making sure they are installed correctly will greatly extend the lifespan of your trailer's wheel bearings and reduce the risk of failure during towing.
On the overloading theme .. there are 750kg trailers manufactured that run dual axles, excellent for towing stability but what are the chances of the gross weight being adhered to as the extra weight of the trailer often means a payload of less than 500kg.
On a similar vein I have issue with kids (or adults) scooters, they all use the same size bearing which IMO are undersized for the kinds of abuse they're expected to cope with, no wonder I have to replace them constantly. It wouldn't take much in terms of (scooter) design to make them say 30% bigger and there's no need for the aesthetics to be hindered to make them slightly bigger. I suppose the fact that it's been a standard bearing size for decades that it'll never change.
Have you tried some quality ones like NTN, Koyo, Timken, FAG or SKF? It would be interesting to see how the same sized bearing from a quality manufacturer would work.
Yeah, but you can't spot it with a camera, so nobody really cares. I have a 2 ton (laden) twin-axle, dropside trailer. If I filled it to the top of the sides with wet sand, I could put 6 tons in it!
This.
It only becomes an issue if it's involved in an accident.
Have seen police outside our local recycling centre examining cars with (very obviously) overloaded trailers.
