- Joined
- 27 Jan 2008
- Messages
- 27,408
- Reaction score
- 3,309
- Location
- Country
Prompted after my vestibule light failed, the bulb had a glass cover, so I had not realised it had a tungsten bulb in it, a BA22d the latter quartz inside a glass envelope, and been in this house 5 years, it did get a fair bit of use, so surprised it lasted so long.
Years ago we had fluorescent in the kitchen, they would last around 5 years plus, oddly the LED used to replace it was rather short lived, and a lot more expensive, and lower light output. Also a 18 watt fluorescent HF lamp on landing, (emergency lamp) and the tubes in that would last around 20 years each, but in the house in general we would swap a tungsten bulb every couple of weeks some where in the house.
So the move to CFL was I thought going to reduce bulb changes, so living room and dinning room had 16 x 8 watt golf ball CFL fitted, together with new chandeliers, allowing us to fit more but smaller bulbs. The spec said they should last 5 years, in real terms after 18 months all the expensive Philips bulb changed to cheaper bulbs, and around this time the LED candle bulb was sold by Lidi, so we experimented with them, first set two small tried 3 watt, these went to mothers house with smaller rooms, and used 5 watt, and 5 years ago when we moved out, no failures.
So this house, the living room had a single 100 watt bulb, which was inadequate, and using 15 watt LED reminded me of the toc H candle, so we needed a chandelier with multi-bulbs, and found one with 8, so now 8 x 6 watt candle bulbs, the spread is not enough for room, so the 5 ikea billy book cases used as display cabinets on narrow end of the L shaped room, had three LED colour changing strip lights, 60 watt in all, to supplement the main light.
Over the 5 years, bulbs changed due to failures and problems staying on dim, or a shimmer, amount to around 25 bulbs. Plus a power supply failed on one strip light. Which with around 55 lamps in the house, is far more bulbs than I expected, as to actually fully failed, around 8 bulbs, but over 5 years that is really more than expected, not counting swapping tungsten to LED.
I have a draw full of bulbs, a mixture of tungsten, CFL and LED, we have two integral lamps, both bought by my wife, which I don't like as one such a pain to change when they fail, and two hard to automate. However outside light only cost £4, and the hall light was an emergency when the original failed, and this is the problem, not keeping an integral lamp in bulb draw, so a failure can take days to correct.
There will always be the exception to the rule, the fire house bulb over 100 years old (although now so dim can't be used as a bulb) or the bulb which fails within minutes of turning on. The GX53
method seems good, swapping a bit more than the basic bulb, but can still swap the lamp in minutes, but what about some thing to replace the 2D lamp, or fluorescent tube in general. What non integral options are there, which are not restricted to a single make of bulb/tube?
I want an easy maintenance home, bulb fails, switch off at wall, swap bulb, switch on at wall, integral fails, travel to find replacement, turn off at consumer unit, so a two minute job turns into a half day job, time to swap on integral unit is longer than time to charge all bulbs in the house. Why even make them?
method seems good, swapping a bit more than the basic bulb, but can still swap the lamp in minutes, but what about some thing to replace the 2D lamp, or fluorescent tube in general. What non integral options are there, which are not restricted to a single make of bulb/tube?I want an easy maintenance home, bulb fails, switch off at wall, swap bulb, switch on at wall, integral fails, travel to find replacement, turn off at consumer unit, so a two minute job turns into a half day job, time to swap on integral unit is longer than time to charge all bulbs in the house. Why even make them?
