Powder coating radiator
Ah you sprayed them sorry. So powder coating should be at least as good
They look like this. They do them in 1000 and 1200. I need an 1100 as this is what is in and I can't alter pipes can't get under the floor is tiled no access
Nope - painted - as I suggested before
No but I have sprayed a few. Changed both my bathroom tall myson towel rads from white - one to black and one to anthracite.
Recoated 2 white rads too.
Hung them on wires from the garage rafters. I found the trick was get them well prepped with scotch brite and then really clean then - 3 full coats of etching primer, 3 full coats of paint and then 3 coats of matt lacquer (satin on the white rads) and let each coat dry well. Couldn't be happier with the result.
This is the anthracite one - again used to be gloss white
Yes a Matt black one. They should be able to get a similar finish you'd think?
I would certainly think so ... I'm sure someone with more experience of powder coating will advise but I believe they can create any finish needed but it does come at a price for bespoke one off's usually.
I suppose you could use some telescopic radiator valve tails and fit the 1000 long one?
Yes I thought of that would need like a 75mm rad tail extension for each side. Don't think would look very good
I have to be honest - I've used them a few times and try to use the solid ones - the telescopic ones leak just by looking at them IME.
I never like them, they just looks naff and very amature'ish IMO.
Yes would be solid ones I think would look poor though too 75mm extensions either side
Edit
It would be 80mm too short for the current pipe centres so two 40mm extensions or an 80. Still I think would look poor
Why have you got your heart set on powder coat? If the radiator you want is already painted, you’re better off wet spraying it.
Edit: looking at the panel radiator shown in your photo, you won't get a decent finish from powder coat.
