I
In Your Face
hi there
In Your Face said:Covering modern cables (1950's onwards) with insulation is the least of your worries when it comes to electric's running through your home.
A fire cannot start due to insulation.
The most important thing is to hope u have not got a plug socket wired up to your lighting circuit cos its things like this which cause modern cables to overheat and burst into flames
also no dodgy wiring with a live wire ready to touch your copper water supply, that would be great fun in the bath. Always check u have the right fuse for the right circuit and never overload the ratings of your cable.
festa said:.
Insulation covering any cable is not good but as pointed out before the effect on a lighting circuit cable is very small ...BUT... can reduce the life of the lamps themselves.
With 12 volt lighting a 50 watt bulb is taking more than 4 amps. Cable size is critical.
In Your Face said:The most important thing is to hope u have not got a plug socket wired up to your lighting circuit cos its things like this which cause modern cables to overheat and burst into flames
No is is not. Covering a cable with insulation derates the cable to a lower maximum current.
oooh Scary, dont cover any downlights or transformers with insulation
But can start by overheated and charred cable igniting flammable material
Sounds like dodgy electrics, the most important thing is to get your electrics tested
and they over heat much quicker when covered in insulation
Once again, get those electrics tested.
The rating is lower when covered in insulation
Rating is lower. Well you wouldnt worry about that if you got hit by 240v in the bath. Get your bathroom bonded
The biggest problem and danger is from installations done by people who think they know what they are doing is correct when they haven't read the books or learnt the full knowledge.
No it isn't.
The worst thing which this could do is cause the OCPD for the circuit to opreate.
The cable will not overheat and burst into flames.
Infact even when I connected a dead short on a piece of T&E to my welder it didn't burst into flames.
When i install downlighters i fabricate an open ended box from plasterboard and give it at least 100mm from the edge of the downlighter to the sides of the box.
You can buy special protective covers for downlighters,which i use in flats but these can be expensive.
festa said:.
festa said:.
Cable size is critical, so i recommend not to use such light lighting
Scan the entire forum, and you will find hundreds of theads (many not very OLD). These are diverse in content, covering many aspects of the electrical installation trade.
Yes, this thread seems to centre on thermal insulation over cables. BUT THAT IS THIS ONE THREAD.
Go read the others, and you will find a good cross section of what you are banging on about all over the place.
One thread is not going to cover every danger involved with the lecky in your home.
You say you have been in the building game? So are you a spark?
Tell us the requirements about bonding ina bathroom.....
