Hi all - I've recently had a bathroom makeover and painted the walls white with kitchen bathroom dulux easycare. I painted over existing light grey walls that had no problems. Since painting after a shower a yellow goo drips down the walls and you can see it collecting on the caulk of the tile trim. All walls are doing it - there doesn't seem to be an area worse than another. If I wipe it off the yellow stuff is transparent and slightly mucusy; kind of like if you leave a tin of paint for ages in the shed and it separates and you're left with a clear-ish layer on top.
But the tin was new, well away from expiry, and i got a large one that i used in the kitchen and utility room all which are fine. I've also painted so many rooms in many houses before - i'm open to user error but I can't think what I haven't done a million times before.
I've researched online and the two main things that seem to come back are cigarette smoke which I can rule out as no one here smokes and the room was previously taken back to bare plaster. And the other is that its a settling in of the paint but it's been 4 months now and it's still happening; making a bit less but still enough.
Ideas really appreciated!
