How to sort this garden tap problem?
14 Apr 2021
The outside tap is leaking. I've tried to undo it but no luck. Also the one I've bought to replace it isn't a match. I've taken a picture of both taps. Any ideas?
Yes, looks like the new tap is correct - the old tap with split from the wall plate at the arrow - you may need a couple of pairs of grips - one to hold the fitting, the other to hold and twist the tap. It will go.
Don't forget some type of sealing tape/cord washer etc for the new one.
Ok. I've been spraying oil in that joint. When you say grips. If that spanners?
Yes - adjustables on the flats will do - shouldn't need WD tho - it's brass on brass so unless you are in a hard water area then you may be up against some scale
Ok I'll have a stronger go at it, thanks.
