- Joined
- 8 May 2017
- Messages
- 10,608
- Reaction score
- 2,851
- Country
Hopefully you have isolation valves under bath to it's taps to at least be able to change them !
Ok thanks Now i just need to undo the bath tub with 20 screws on each 6 planks -.- then I'll find out if i can turn the water off under.. If not would be the stopclock outside?You will get cold water if it's from the mains ,which it almost certainly is. You get hot water from your baths hot tap because it's much lower than the little cold water tank that is sitting above the hot water cylinder ( it's integral ,looks like part of the cylinder). Once you start to raise the hot outlet ,the pressure drops. Judging by the measurements you gave ,your shower outlet will be virtually higher than the hot water cylinders top ,and pressure will be zilch !!
Ill be asking the landlord Wednesday...I have no idea what or where any stopcocks to the premises exist. Typically there would be one outside that closed the supply to the building originally. When converting a building into flats it's not uncommon for additional supplies to be laid in. Worth asking neighbours if they have any in their flats.
Ok so I got one them croyex shower plugins that go on the taps. The hot shower works at my height lolI have no idea what or where any stopcocks to the premises exist. Typically there would be one outside that closed the supply to the building originally. When converting a building into flats it's not uncommon for additional supplies to be laid in. Worth asking neighbours if they have any in their flats.
I dont know if I can get the same tilesI am surprised you get a useable hot shower ,but if it works for you all good !
As for wall protection..... additional tiling not an option ? If you ain't too bothered about appearance ,drape shower curtains around the walls.
