Upgrade or renew existing system?
Texecom or pyronix will be fine , just set the rear unit to scb or low current , the pyronix is led strobe so it won’t pull as much as the Texecom unit
If I was to replace the system, would I be better off with a Texacom Premier Elite 24 or Pyronix Euro 76?
Thanks!
Pyronix cheaper and easier to program but annual app subscription
Texecom more flexible ( if multiple areas needed ( NOT part sets , app free but panel more expensive to start with
Can be a bit complicated for a diy installer ..( more things you could get wrong )
I am looking to get an installer to set it up and replace the external sirens... given it will be an installer who will install, do you recommend I go for the Texacom?
If he is happy to install the texecom …go that way …but check the what the price difference is …
Thank you, you have made my decision , the cost for installation is £260 regardless, I will purchase the material… the cost difference for the texacom and pyronix is £38 with the texacom at 309 and pyronix at 271 (excl VAT).
What’s your parts list ?
I have attached the invoice, on the pyronix I have deducted the cost for the LAN but kept the WiFi module, I also have a damaged PIR that requires replacing
