Yet there are special skirting boards designed to run cables in, also dado trunking the same, so it seems there are exceptions to the rules not quoted.SKIRTING BOARDS
You must never run cables horizontally behind skirting boards unless they are enclosed in earthed, steel conduit. Vertically from under the floor to a socket on the wall above the skirting is fine.
It does, but it doesn't cite any source for said claim.It says at the bottom of Wiki page
My understanding is there is nothing special about skirting boards per-se, it's just that there is no "safe zone" at the bottom of a wall.Yet there are special skirting boards designed to run cables in, also dado trunking the same
True, but I suspect 'no worse' than the "ties" that are required to be installed between inner and outer leafs of a cavity wall?...... 2. Unless clipped in place, there is a good chance that the cable touches both the inner and outer walls. As such there is the possibility of it acting as a "bridge" carrying heat or moisture between the inner and outer skins. I question how much of an issue this is in the real-world though.
Its not electrical regs, its building regs & bad practice.Rubbish.
It is totally illegal to run cables in cavity walls
Which is it?the installation of cables within cavity walls should be avoided.
Read above.Which is it?
It is totally illegal to run cables in cavity walls as there are still quite a few cavity insulations that dont have a fire ratting. Especially the blown in types. Some do, but many dont.
So - you were wrong.OK, but if i was the builder i would kick the sparky off site. There are lots of guide lines although not a rule, for good reason.
That is just laziness.
