Could it be that this filter needs emptying, it appears to be towards the end of the gauge
Pressure gauge?
Can you send photos?
Yes, it is on the return pipe and pointing down.
I meant the guage on the filter. There is an arrow pointing to a yellow line and it is near the end of it.Pressure gauge?
If your boiler is above it, it should be pointing up!
It should be pointing towards the boiler.
No, not changed it. Just photo angles. Could this thing be full of crap and need emptying?That's to indicate correct and incorrect closure of the lid.
Have you just tightened it because your latest photos look like its in 2 different positions?
How about power rating? I have it on 9.1KW. Could be a bit lower or much higher
Is this easy to fix?likely the auto air vent in the boiler is blocked or closed down.
But there isn't any problem with pressure build up. Gauge stay at same low (green) level.likely the auto air vent in the boiler is blocked or closed down.
