Hi there, I have a small downstairs bathroom, just over 6' x 6' x 9' and all the walls are tiled. The existing fan is a cheap Manrose Gold in external wall diagonally opposite to the shower. Anytime the kids take a shower the water is literally running down the walls. Also the fan tube goes to the corner of a large airbrick on the outside wall. Doesn't go through it, just rests against it so I guess a fair bit of the moist air is just going into the cavity.
Wondering if it's possible/ok to put an inline fan (Manrose MF100T) in a box on the outside of the external wall and run the ducting back up and into the hole where the existing fan is?
The benefits would be:
Minimal mess in the bathroom and easy to carry out work.
Channeling the ducting through the airbrick in a pipe stops moist air ending up in the cavity.
The fan noise would be outside so nice and quiet.
Easy to access for maintenance.
The existing isolator is postioned about 6 inches from the fan and would be easy to replace and run the cable - is it ok to do this regs/rules?.
Regards sitting the fan in a box (I would waterproof the box) - does it need ventilation to stop overheating, e.g, grill on the underside, a lot of airspace in the box?
The instal instructions only show it being posititioned horizontally - wonder if its ok to fit vertically to avoid any condensation issues?
Thanks in advance
Thanks in advance
