Ive cut mh BNC cable .
14 Oct 2023
Hey guys
I tried putting up cctv.
I've made a stupid mistake by cutting one of my bnc cables to make it easier to push through the hole in the wall. I cut the cable from 10 inches or so away from the bnc connector so I can reattach it again.
There's a white and blue wires inside the cable. But there's also a kind of skinny metal conductors wraped around these wires. I've tried to connect the 2 wire together rand even the metal conductor thing. It's not working the camera.
Have I messed the cable up?
Any tips?
Could you post a picture of the end you've cut off (with the connector/s) and the end of the cable?
Admittedly I don't have experience with CCTV, but the BNC cables I've dealt with have all been co-axial, very rarely tri-axial.
BNC is the type of "connector".
The Cable is "Co-Axial".
See https://en.wikipedia.org/wiki/BNC_connector
You may need to obtain a "mating pair" of BNC Connectors and a length of appropriate cable to repair it.
Yes.
There is an (one) insulated conductor inside the co-axial cable
and
there are stranded (shielding) wires over insulation around that single conductor.
This is why it is called a "Co-Axial" (Same Axis) Cable.
Post a picture. I can't decide if you're talking about a coax cable that's paired with a power cable; I wouldn't expect a blue and a white core inside a coax cable, unless you're getting confused and thinking the typically white insulation is a core
What was written was "There's a white and blue wires".
A combination of singular and plural - which "does not compute".
(Perhaps the insulation was White and Blue striped - although I can't imagine that to be so ?)
In any case, a BNC connector is for a Co-Axial cable,
with one internal conductor surrounded by a stranded shield conductor.
Here's inside the cable
That's what I thought.
It appears that you have cut through the power supply and coax cable.
How were you thinking of connecting up, before you cut the cable - were you going to feed the cut section in from the other end and join them in the middle?
Although rather than faffing around, it may be better to replace the cable.
If u look carefully u can see the outer copper bit there as well. Which in this pic I haven't joined together... but that is very 'flakey' ie falls off easily.
It's either this the problem or i think i have nicked a cable outside when I was clipping against the wall.
Theoretically if I was to join the copper together and tape it. Would that be OK?
Then I should look outside if there's issues with the cable?
Try connecting them together in a terminal block, something like...
In the photo, I see a screening wire, which in your photo remains unconnected, one end to the other, which will certainly prevent it working.
Ideally, you should connect those wires, by soldering the joints, then use some heat shrink tube over the top. Second-best way, is to use connectors, but remember you must also join the screen/ the outer copper fine wires too.
