Help to source similar size flush door latch summer house door. Can't find anywhere
22 Nov 2019
As per title
Looking for simar flush latches as per attached photos. Any idea where could find those as new one seems to be bigger and wider than my doors
If you are in UK the faceplate is probably 5 inch x half inch. The case will be smaller.
Put an imperial measure against it.
Also turn the latch sideways and photograph the working parts. I can't make it out. It's not a flush bolt, is it?
I'm in the UK and this was installed on old summer house door that I'm restoring. The one in the photo was still screwed in and the other one missing. In inches you correct 5 x1/2
Can't anything 1/2 wide
It is flush as this was inserted on the side door to make it flush otherwise you couldn't close the other door
