Yes, those are the mounts.
I'd use copper but plastic should be fine if used correctly and inserts are used.
No wiggle room on the 150mm centres as those are the pipe centres on the bar valve. I have a piece of plywood with 2 holes drilled the correct distance apart which I use to hold the pipes in position during tiling.
