- Joined
- 24 Aug 2009
- Messages
- 2,717
- Reaction score
- 293
- Country
I just fitted my winter-wheels last week ( just in time as there have been heavy falls since ) and would like your views on the following.
These Avon WX7 tyres were fitted on my Vectra C in Jan 2022 and have covered 10 700 miles since. Tracking was done at the same time and new drop-links were fitted. One drop-link failed after 6 500 miles and was replaced.I can't be certain if worn tyre was on this corner but think it likely. I'm not aware of any bangs on wheels from hitting kerbs or pot-holes to knock wheels out of alignment.
Before fiting the wheels I measured the tread -depth ( was 6 mm when new ) and found three tyres with 4 mm on the outer edge and 3 mm on inner edge. One had 4 mm outer and 1.8 mm inner.
1) Would you normally expect to find a differential between inner and outer edges ? I am not certain if tracking is meant to (hopefully ) eliminate any effect of road camber ( I sometimes think the camber seems quite sharp here: no idea if mountain roads have different specifications ) as well as contributing to steering ability.
2) Would a worn-drop-link have any effect as seen on the excessively worn tyre ? I had it changed about 120 miles after I first heard clunking.
3) Is tracking adjusted per wheel or per side i.e. could a screw-up have affected one wheel but not the other on the same side ?
4) Is it likely that a well-established small garage selected by personal recommendation would make an error ? I'm assuming it's not a particularly difficult job.
Now awaiting your inrush of ideas.
Edit: I will get the tracking checked asap, but garages are inundated as the first snow-falls mean ..........a big rush for winter-tyres, especially as the law now requires winter-tyres or chains/socks for the car in mountainous regions.
