As you say,that's certainly an option.Yes, two radials would certainly be an option, although in all likelyhood oversized for the expected demand. They‘d probably use less cable than a ring.
As I always say, although I'm sure that it will usually not be an actual problem in practice, I am personally not all that comfortable with 20A (or 16A) radials, since it doesn't seem ideal to have umpteen "13A" outlets on a circuit when, at least in theory, just two loads could 'overload' the circuit.
I'm perfectly happy with 32A (4mm) radials or, if devices are available for the CU, 25A ones, since, cable-loading-wise, there are no worse than 32A rings.
