- Joined
- 8 May 2017
- Messages
- 10,551
- Reaction score
- 2,816
- Country
Are all the thermostatic valves ( big white top, right hand side of rad in your pic) turned fully anticlockwise ?
YesAre all the thermostatic valves ( big white top, right hand side of rad in your pic) turned fully anticlockwise ?
I have found some Pipe connections towards the back of the cupboard. The one that feels hot leads to the Motorised Valve, The other one feels cold and comes from the Boiler Return Pipe, at the bottom of the cylinder.Latch the other motorised valve to manual ,if rads still don't heat up you have done all you can and need an engineer to visit .
Don't forget to return both valves to auto once finished the test.
Despite this my pressure remains low, can you suggest any other way for me to top up the water in the tank, with a flexible Hose? What would happen if I attach a flexible hose from the cold inlet to the boiler return pipes? is it even possible? What about Re-pressurizing the expansion tank?Latch the other motorised valve to manual ,if rads still don't heat up you have done all you can and need an engineer to visit .
I believe it s a Range Tribune HE Unvented Indirect Hot Water cylinder Tl120Do you know the make and model of the boiler? The expansion vessel is for potable water, not the heating water.
If thats all the Range Tribune does, then why are there central heating components sticking out of it? Shouldn't the Communal boiler be direct tot he radiators then?The boiler is what provides the hot water that gets pumped around the radiators ,and if it's communal as you told us ,it goes to all flats.
All the range tribune does
Is heats your hot water for taps .
Nope, that’s a cylinder, as you’ve even stated.I believe it s a Range Tribune HE Unvented Indirect Hot Water cylinder Tl120
It does go to the radiators and is on when there’s a demand for it from the room thermostat. You have an indirect cylinder (indirectly heated) which is heated using the central heating water which is diverted via a motorised valve when requested. Th heatingIf thats all the Range Tribune does, then why are there central heating components sticking out of it? Shouldn't the Communal boiler be direct tot he radiators then?
