I am buying my first house, and I'm losing sleep over it as I've got a really bad feeling that I'm paying too much for a potential money pit and something that might be difficult to resell, even in the booming local property market where I am.
I'll summarise the situation and perhaps some here can tell me how valid or invalid my concerns are:
1. House listed at £215K and bid up to £235K, a good £20K over what anything in that street had went for before. However it looked in great condition, new roof, heating system, driveway etc...in recent years, even if it is a small house.
2. I know via a third party that the EA actually put a stop to bids after a certain point, because I had such a large deposit and made it clear that £235K would be my last bid (this detail will become important in a second).
3. First red flag - mortgage company came back with a value of £220K on the house; £15K less than I'd bid. I didn't think anything of this (in retrospect I should have).
4. The homebuyers survey throws up three critical things; some horizontal cracks in brickwork indicitive of wall tie corrosion, a slightly cracked/worn concrete lintel, and some damp in the gable wall in the attic (the attic is plastered/boarded/carpeted with a big velux window).
For context, this is a 1930's brick house, that has had cavity wall insulation installed in 2012. It is in a part of the UK that rains quite a bit; seems to be in a severe driving rain area according to the maps.
The more I read about this the more I worry that a house like this shouldn't have had cavity wall insulation put into it, and the wall most exposed to driving rain (which is the one with the small cracks appearing between bricks), will always be letting enough water in that the cavity wall insulation is going to be wet and ineffective and actually causing damage, i.e. its not the age of the building causing wall tie corrosion, its the cavity wall insulation causing moisture to gather between walls which will cause further issues down the line.
5. I have negotiated enough money off the house to fix the wall ties; but my solicitor has still warned me against buying the house; saying that wall tie fixes can be a nightmare, and even with wall ties fixed the house will appeal to a smaller range of future buyers as just knowing that there were wall tie issues in the past will put a percentage of buyers off as it will change their 'perception' of the house and will highlight that it's an old house. He also said that mortgage companies might not lend on such houses as easily. Does this ring true with anyone else?
6. The other big fear is that if I do get the wall ties fixed 'properly' which appears to be the old ones removed too; the brickwork will look really patchy unless I get it repointed which will once again cost a fortune and might leave it looking worse if not done right.
7. There is a garage conversion to a home office that looks really well done (no central heating), however whilst it has planning permission it has no building control sign off and the vendor can tell me very little about what was done during the conversion. The garage conversion was a big selling point to me but I viewed the place in warmer weather and I think I might have been a bit of an idiot forgetting how bloody cold it is here for half the year which might render the room useless.
