    Dismiss Notice
Deep rendering cracks 1930s house
Discussion in 'General Discussion' started by Veranella, 11 Jun 2021.
  1. Veranella
    Veranella
    11 Jun 2021
    5
    Thanks Received:
    Country:
    Hello,
    I was wondering whether anybody has experience with cracks in bay windows in 1930s houses. I am buying a house and the building survey revealed some deep cracks around the bay windows.
    Here is what the report says about the walls:
    “… My main concern was the cracking to the rendering of the bay windows especially at first floor level. The photos clearly show some very deep cracks which have caused the render to come away from its sub base. The pallet knife went in 100mm. This will need to be investigated further by removing the rendering which will indicate how serious the problem is and whether the wall/sub-base is effected.”
    I am adding some photos from the report.
    I realise without seeing it for yourself it is difficult to say for sure from the photos only (and obviously I understand that the surveyor advises to investigate it further), but does it look on the photos like something to walk away from? I know that things can be fixed and it is only a question of money…. My main concerns are (1) potential problems with getting insurance for the house and (2) if the issue is serious, the cost of fixing the issue (I assume it cannot be put on the house insurance since the problem exists and I know about it before getting insurance). Anything else I should worry about?
    30424490-C2F1-4148-AAC4-53CBF999FC40.jpeg B00F5F09-C919-47B3-B2F4-06B929321188.jpeg F77CCD85-CC65-494C-9244-F22D09A36B31.jpeg BCED02A6-AC03-49B9-8637-A88C35E1216F.jpeg
  2. Sponsored Links
  3. trazor
    trazor
    20 Jan 2007
    5,236
    Thanks Received:
    238
    Cornwall
    Country:
    Walk away, there are thousands of other properties.
  4. transam
    transam
    20 Nov 2009
    29,587
    Thanks Received:
    3,580
    Surrey
    Country:
    Worst case scenario
    foundations ??? Under pinning and all that expense
    may be possibly ?
    ( not a builder )
  5. Lower
    Lower
    22 Dec 2005
    2,030
    Thanks Received:
    285
    UK
    Country:
    Bay windows in houses of that period were often built without proper foundations and consequently its common to see cracking as the bays move in relation to the house.
    Our last two houses had it, to a greater or lesser degree. Its the severity that you need to be concerned about.
    it would be useful to have some pictures taken further away to show context, but i doubt you'll have any problems getting insurance but you probably won't be able to claim on your insurance for the remedials as it was a known problem when you bought the house.
    • Thanks Thanks x 1
  6. Scarlet Pimpernel
    Scarlet Pimpernel
    9 May 2020
    7,402
    Thanks Received:
    132
    Country:
    France
    Images from a few meters further away would help.
    If you don't fancy any remedial work, then take the advice and walk away.
    Otherwise if the house is attractive to you for other reasons, it might be possible to conclude whether it's just the bay window that needs remedying, and a useful discount could be negotiated.
    Are there similar houses in that street? Have they been remedied? Do they look as though they've had similar problems?
  7. Veranella
    Veranella
    11 Jun 2021
    5
    Thanks Received:
    Country:
    I was looking at another house on that street before I saw the one I am buying, and that other house also had some cracks. That other house was better looked after though and those cracks were filled (see the photo of the other house attached). And I was also told by the owner of that house that other houses on the street, apparently, had this issue too.
  8. securespark
    securespark
    11 Jan 2004
    36,573
    Thanks Received:
    1,240
    Country:
    Someone I knew was considering purchasing a similar property and allowed 10K for repairs.
    • Like Like x 1
  9. securespark
    securespark
    11 Jan 2004
    36,573
    Thanks Received:
    1,240
    Country:
    I have a similar issue to fix Chez Secure, but I don't have bays and I know the issue is not related to ground movement.
    Just had a quote for 5K plus whatever is under the render. Need to get some more quotes but getting people round is a nightmare! We had to pay this builder for the quote, £96, refundable against the job if we go ahead.
    • Thanks Thanks x 1
  10. Sponsored Links
  11. trazor
    trazor
    20 Jan 2007
    5,236
    Thanks Received:
    238
    Cornwall
    Country:
    That "filling" could just be cosmetic, and may hide a deeper problem.
    Unless you have compelling reasons to purchase, as I said above, walk away.
    Selling in the future, will provide another set of problems for you.
    • Thanks Thanks x 1
  12. ^woody^
    ^woody^
    3 Sep 2006
    33,004
    Thanks Received:
    4,468
    West Mids
    Country:
    Poxy surveyor' report.
    Those cracks are years old, and cracking is typical on all tradditional house bays. There is no evidence of current or progressive movement from those photos or cracks, and your surveyor should have explained that.
    • Like Like x 2
  13. blup
    blup
    5 Nov 2007
    1,581
    Thanks Received:
    273
    Country:
    There is some evidence of a previous localised repair in the second pic, grey render/stones contrasting with the sandy coloured original.
    Ask your surveyor to confirm whether in his view there has been recent movement. If you're getting a mortgage what will they want done, if anything, as a condition of the loan.
    Blup
    • Thanks Thanks x 1
  14. motorbiking
    motorbiking
    31 May 2016
    6,455
    Thanks Received:
    729
    Country:
    What does it look like on the inside? I note they have installed UPVC windows. many original 1930s houses had the windows built in as part of the build so they became structural.
  15. Veranella
    Veranella
    11 Jun 2021
    5
    Thanks Received:
    Country:
    Yes, I believe the front windows were replaced. On the inside in the ground floor the window sill has a gap underneath it like in the photo.
  16. motorbiking
    motorbiking
    31 May 2016
    6,455
    Thanks Received:
    729
    Country:
    Is it a single skin bay window? i.e. about 5" thick?
  17. Veranella
    Veranella
    11 Jun 2021
    5
    Thanks Received:
    Country:
    I’m not sure I know what “single skin” means. I think they are double glazing (but I suspect this is not the correct answer to your question )
Loading...
Share This Page
