- Joined
- 10 Nov 2024
- Messages
- 7
- Reaction score
- 0
- Country
As part of a renovation project, we have had underfloor heating retrofitted downstairs in two rooms and a hallway.
Insulation has been added between the joists and then pipes (16mm I think) have been laid across aluminium spreader plates. Above this is 22mm chipboard flooring.
The rest of the downstairs extension has been fitted with underfloor heating pipes in screed. We have had a heatpump installed.
I have two questions:
1. We've noticed that the retrofitted rooms don't get particularly warm. Is this always going to be an issue with 22mm chipboard? Apparently the heat pump engineer specified to the builder to use a more thermally efficient thinner gauge board. I've only taken up a small piece of flooring to investigate as I don't want to damage the flooring unless I have to. Photo attached of the pipes under the floor - this section is close to where the floorboards meet the concrete. I hope this is why one of the pipes isn't sitting inside the spreader plate.
2. The chipboard flooring creaks quite badly. The builder has claimed this is due to expansion/contraction caused by the UFH. I suspect we are being fobbed off. I realise there might be a number of causes of this. On the face of it the boarding looks to have been laid well and glued where the tongue and groove sections meet. I wondered if it might be as simple as the wrong type of screws being used to screw the boards down? I've read various other threads which suggest using Spax or ScrewTite flooring screws to prevent squeaking.
