- Joined
- 12 Oct 2024
- Messages
- 277
- Reaction score
- 63
- Country
Hi everyone!
As you will see below. I have two rooms that are inter connected. The family room (not what we call it, fk knows what that's about), is a 1970s extension. The doorway between them is quite narrow and is an open archway. Not wide enough to fit a door frame and door. I want to make them separate rooms as shown by using a stud wall partition within that room, which would be insulated and plastered. I would take the opportunity to introduce a cupboard in the middle section, and at the end would be shelves that face into the family room, partly to avoid a cold spot against the outside wall.
Anyway, just wondering... there is currently laminate flooring down. Thick stuff, 12mm plus 3mm underlay. A tradesman I discussed it with said to build the stud wall on top of the laminate. Whilst this would look better and involve less hassle, it doesn't seem wise from a long term point of view, like if I need to change the flooring in future? So better to use a multi tool and cut out a trench so the wall can be build up from the concrete, but leave the remainder of the laminate as is? Thoughts?
Also, would this project require a building certificate?
Thanks v much
Thanks v much
