Did you attempt to connect one of the units to the cat5 lead in your garden room?
Why does that right hand router have red x's above two of the ports, and a tick above the third one? Any port can normally be used.
I think it's not a router, it's [probably] an ONT, the fibre equivalent of a modem.Why does that right hand router
LOL, or not, it's a "Strong Atria" [no, me neither] mesh wifi thing.
I thought I'd post pictures....I'm wondering...last night nothing was being used in the house whereas today my wife has two laptops on the go and her mobile...If it's an access point, there won't be a WAN light. What's the model number?
Test the cable by plugging a laptop into it first; laptop in the shed, router in the house. Do a speed test tooDo you have any idea why it works then doesn't work please...
Well, not only option but for the cost of a pre done and verified wire versus the worth of your professional time messing around fixing this one, it's probably a hiding to nothingI think buying a Cat6 with connectors factory fitted is my only option
The 'manual' is dreadful... I guess the 'Atria Strong' is a 2 piece system; the Left hand box plugs into a LAN port on the Incoming Router, it has it's 'own' communication standard between that box and the slave box where the link cable plugs into the 'ticked' port, presumably a WAN port but may recognise it's comm's standard.Why does that right hand router have red x's above two of the ports, and a tick above the third one? Any port can normally be used.
So the signal dropped out completly yesterday on the cat5. As suggested I plugged it into the laptop in the shed and still in the same Lan Port on the router. Eventually I managed to do a speed test which gave a Download of 1.59mbps and upload of 5.59mbps which is pants
My experience is solid is better but do ensure you have the right plugs they are different for solid and stranded, that aside I wouldn't suggest using stranded for a 30m run due to the reduced performance.That suggests either the cat5 is damaged, or you have used the wrong colour pairs, when making the ends off. The testers, only confirm the same wire is used at either end, they cannot check the pairs of wires, have been maintained as pairs - you have to do that visually.
Another potential issue, is that the crimp on RJ45 plugs, don't work reliably with solid wires, they work best with stranded cat5. A more reliably work around, is to install a socket at either end of the cat5, then use a pre-made short cable, from the socket, to the router, or AP.
