- Joined
- 6 Mar 2009
- Messages
- 198
- Reaction score
- 11
- Country
Had a problem with a toilet cistern filling only when a cold tap was run - played with the (Siamp) fill valve washer cover, and it seems to be fine - maybe a bit of limescale.
In the process of putting the fascia board back on, the flush cable appears to be stuck. There’s no resistance to, or engagement with, the flush button, and manually lifting the valve and releasing causes it to refill and overflow into the bowl.
I can’t lift the lid off to access the cistern to swap anything, because the cam-locked top panel has a basin unit fixed over one side of it…
Is the plastic piece which engages with the flush button supposed to move with the cable? Not what I need on Christmas Eve!
