None. 2.5mm^2 cable must not be connected via a BS 1363 plugtop.
Can you quote the reference to back up your fable?None. 2.5mm^2 cable must not be connected via a BS 1363 plugtop.
Sling the fitted flex away and fit a 3m one instead. Hardwire to the usual outlet.. I do want to connect it via a plug so that I can lift it out if necessary for cleaning.
No I said the actual reference, I've worked with the part of BS1363 where the license was granted to use plugs without internal fuse and the requirement to use 2.5mm².BS 1363.
Does that actually impose a prohibition on the use of, or terminals designed to take, 2.5mm?
Or is it simply that it doesn't have a requirement to take 2.5mm?
View attachment 367091Does that actually impose a prohibition on the use of, or terminals designed to take, 2.5mm?
It's a specification that plugs are made to. 1.5mm² is the maximum size of conductor specified.
Someone could theoretically make terminals which accept larger conductors, but that would be entirely pointless so it's not done and never will be.
Flex emerges from a hole in the case - I'd have to open it up to get at it, which would probably scupper the warranty.Sling the fitted flex away and fit a 3m one instead. Hardwire to the usual outlet.
Hob can now be taken out and placed aside for this mythical cleaning where the hob is taken out on a weekly basis and hopefully not dropped and broken every time.
Or just fit the usual seals around the hob so cooking mess doesn't end up under the edges of it.
I can not see the argument here!.
does not conflict with terminals that actually are capable of taking 2.5 flex.
If a manufacturer is able to make such a plug that satisfies both requirements without negating the other then what the heck is the problem?
They could.Someone could make a plug which took 2.5mm if they wanted to, and it would be perfectly OK.
