- Joined
- 18 Apr 2022
- Messages
- 7,217
- Reaction score
- 1,087
- Country
I have several. Why wouldn't I?Who still has an old style 'ordinary' type, plug in, dial or button type phone?
No idea, I don’t know you. Hoarder maybe?I have several. Why wouldn't I?
No, it's because until BT ripped the supporting infrastructure out, hardwired phones were the best solution in a house which was fixed to the ground and didn't move about.No idea, I don’t know you. Hoarder maybe?
Don't need any ADSL filtering for phones now.What I did was to get OR to install the NTE 5 with the unfiltered faceplate, then I ran a normal phone extension from that upstairs to where I wanted the router, where I installed a NTE 5 with filtered faceplate to which I could connect both the router and a phone. For the dowstairs phone extensions I just connected them via an ADSL filter to the NTE5. Worked fine.
However, is it possible that any such "power outage" would also affect the "cabinet" where the Optical Fiber/Copper interface is located,So I plan to buy such a unit to power all the equipment needed to stay powered to keep the line and carecall going.
The NTE5 socket represents the official demarcation point between the internal/domestic wiring (at the removable front of the socket which is the customer's responsibility) and the external telephone line/cabling fixed at the rear (which is BT's responsibility) the physical disconnection of the two sets of wires (made possible by the NTE5's removable front plate) is crucial in identifying faults and allocating responsibility for their rectification.Anyway - returning to this...
Switchover happened a while ago, the NTE5 is still where it was, and the BT hub is roughly in the place where I want it, plugged into the NTE5 with a loooonnnnggggg flat RJ11 cable. I don't like the route of the cable, and when I re-route it it will have to be even longer.
I could leave the NTE5 where it is, but I'd rather move it to where the hub is.
Is there a limit to how long the cable from NTE5 to broadband modem can be?
Would Cat5 with an RJ11 at each end be better than the flat cable?
Would moving the NTE5 and extending from the incoming dropwire be better?
You need to dis-connect the non-working BT connection
Poo. Didn't think of that.However, is it possible that any such "power outage" would also affect the "cabinet" where the Optical Fiber/Copper interface is located,
unless the "Cabinet" also contains "Back-Up" batteries?
