And if the unit currently has a 32A plug, it probablly has a 4mm² flex, getting a 13A plug on that is likely to be somewhere between very difficult and impossible, whereas getting a 16A commando on is likely more doable.
it wouldnt be hard to swap the wire im more just talking logically it makes more sense to swap the commando with a 16amp than try to put a 13amp plug on it in my head atleast
You're going to have to do something, even if it's just buying and fitting a commando plug (more expensive than you might think) that can't be used anywhere else in the house. I don't see why you need a new 6.5m cable
You could have a simple fitting of a more common type
"Much" is pushing it, the recharge times on 3K/5K UPSes tends to be long (in the region of several hours at a minimum), compared to the usual output load current it's usually negligible.
Having said that I've used normal rackmount UPSes like this in slightly grubby unheated environments at a previous job and it didn't look too well by the end of it, signs of rust on various elements and it drew in a lot of dirt and muck, they're really designed to be used in a clean indoor space.
I've known car batteries, absorb 20amps, when first put on charge, from a partial discharge. I accept that rate can decline rapidly, but nonetheless...
