Best plug I have found for use with 2.5 cable is the mk toughplug
If there long ferrules suppose you can wrap them round a bithow does the ferrule work with them then? Does just half the screw just clamp down on the ferrule ?
Likewise I've been using Permaplugs for a very long time for 2.5mm² cable.I made 13-16A 2.5 campsite lead adaptors with a plug very similar to the one morq posted.
No problems, been using it years.
In your opinion...Well I am hoping that is now put to bed (I`m going to bed in a minute).
That standard says that the plug must take 0.5 to 1.5 flex satisfactorily.
That standard does not say that the plug must not take a 2.5 flex satisfactorily so it might do or it might not do.
If a plug exists that does do both then fair enough.
If no such plug exists then fair enough.
No conflict there as far as I can see.
So what in your opinion is the correct way to construct an extension lead which is too long for 1.5mm² cable?In your opinion...
Avoid doing so. Unless it's an extension lead for BS EN 60309 connectors.So what in your opinion is the correct way to construct an extension lead which is too long for 1.5mm² cable?
How does work when the distance between the power source and the reqired location?Avoid doing so.
Oh and how does that comply with regulations in a domestic situation?Unless it's an extension lead for BS EN 60309 connectors.
I didn't mention using it in a domestic environment. What length of extension lead do you believe that you require in a domestic setting, and why?How does work when the distance between the power source and the reqired location?
