- Joined
- 17 Apr 2007
- Messages
- 2,741
- Reaction score
- 147
- Country
2004 Bora TDI
Like my 2003 Bora TDI, I plugged my new Topdon scanner in to fault find.
With the 2003, it reported a rear sensor which I replaced and that switch off the triangle and abs lights.
With the 2004 I'm now doing, the warning triangle is lit and the abs is flickering as soon as the ign is switched on. They both stay lit with the engine running.
I did a scan which reported the front right wheel sensor which I replaced yet the warnings are still lit.
The abs sensor is just under 1k ohms and the cable voltage from the harness is 2.3v, both which I believe are the right valves.
Would I be correct in presuming it may be a abs module error?
Anyone had this bother?
