Hello - how would you go about accurately cutting 45 degree mitres on 170mm high skirting? I have an old (and cheap and nasty) mitre saw where the arm visibly moves left-right and I have to cut the boards flat which I believe gives rise to potential cupping in the cut. The fancy mitre saws like Makita LS1219L 12" Sliding Compound Mitre Saw doesn't seem to cut as much as 170mm high boards (I think)? Also pretty costly for one job although I'm sure it'd be very handy (thinking about justifying it with my wife...).
While I'm here, some of the wall to which the skirting is going to be attached is missing, that is, it's plastered down to below 170mm from the floor but in places there are gaping holes (flint walls). I was thinking of patching these with carlite bonding ready to use a grab adhesive for sticking the skirting. Sounds sensible?
Ideas appreciated!
Many thanks
Ideas appreciated!
Many thanks
