Hi all, I have just fitted a new shower room with thermostatic shower and a basin. because our water pressure is awful I also fitted a 270lt tank with pump, so there is plenty of pressure/flow. There is already one thermostatic shower in place. See diagram for pipework.
The old shower works great with this setup, pressure is so much better than before.
The new shower never gets more than lukewarm, even with boiler set to 60 (max). I already replaced the thermostatic cartridge (see other thread haha) but still the same.
- With the shower off, the basin tap DOES get hot, then if you turn the shower on as well the shower starts hot for 30 secs but then both the shower AND basin tap go lukewarm.
- If the old shower is running, then I turn the new one on, the old one also goes lukewarm after a few seconds.
Is this some kind of balancing issue? See pic - The pipework from the tank is 22mm until it splits off to go to old shower, and new-shower-plus-boiler. All other pipework is 15mm. I took the cold feed for the new shower off from the boiler cold feed about 50 cm before the boiler as that was a handy place.
