Damp corners and reveals
5 Dec 2012
H
Just refreshing one of the bedrooms
I live in a 1902 2 up 2 down terraced
In the corner of the external walls the paint is still wet to touch (24hrs later), also a bit next to window inside the window reveal
I know it’s obviously a cold wall
Would painting it with damp proof paint before finishing it be a solution?
I don’t want to have to re do all plastering
Cheers
find out why the damp is occurring
send a picture it could be cold bridging due to a lack of insulation or high humidity.
Is the room well ventilated? Do the windows have trickle vents?
That looks like condensation. You need to reduce humidity and invest in a dehumidifier.
Have you got a humidity meter?
I have the window open but I do dry clothes in there (with window open a jar).
The radiator has only just been replaced as it’s not been heating up correctly
I have a dehumidifier, I shall put it on and see what happens
Cheers for help
Don't put any paint or damp seal or anything on top of it till it's dry ....
I assume it's water based emulsion
Get the radiator on for a few hours
It should cure in a day
Cheers for help
As said its OK to dry clothes indoors sometimes ....we have no choice in the UK really .....but u must use a combination of heat , window ventilation and a dehumidifier from time to time as at this time of year moisture has to have a helping hand to go away .and in some colder rooms it will stick around till the spring
Painting in damp rooms will soon show it up
