- Joined
- 27 Oct 2020
- Messages
- 112
- Reaction score
- 8
- Country
Hi, I have a Kia Picanto which I bought a few months ago. I used it for a few weeks and then left it in my garage, as my wife and I each have a car, so we alternate which car we drive every few weeks. After two weeks of not being used, I went to use the Picanto and found the battery was completely flat. I thought it was probably because the battery was on its way out when I bought it, so bought a new one. After not being used for four days, the battery had gone flat again. I realised that something was draining the battery, so I watched this video on Youtube:
and with my wife holding the multimeter, I saw that the car was drawing 0.7A from the battery, when everything in the car was turned off. I found that if I removed the 30A 'B+' fuse, as shown in the diagram below, the 0.7A went down to 0.3A, and went back up to 0.7A when I reinserted it. I tried all of the other fuses, and none of them made any difference. After spending a long time on the internet, trying to find out what 'In Panel B+' actually meant (I'm no car mechanic), I found out that it was the 'Battery Positive' going into the fuse panel in the car. (There is also a second B+ 30A fuse, in the lower right of the engine compartment fusebox, also shown in the diagram below - removing that fuse made no difference to the current being drawn. I'm not sure why there are two of them.)
I then removed and reinserted the fuses in the fuse panel inside the car. I found that the boot light was on, even though the boot was apparently shut. I pushed the back of two of the rear seats forward so I could see the boot light when the boot was shut, and the light was still on - so I removed the light bulb itself, so that at least I would have time to fix the problem with the boot door sensor, without draining another battery. I checked the multimeter and it said it was taking 0.3A, which was still too high, but after a minute, (exactly a minute), it went down to 0.01A. I took the multimeter probes off and then put them back on - it said 0.3A again, but after exactly a minute it went down to 0.01A. I thought that there must be something taking some current when you first connect the battery - probably the ECU, and I presumed it went off after a minute and that was it.
How wrong I was. The next day, I tested the keyfob, which opened the car, and turned on the headlights, and they worked fine. I didn't bother starting the car, because I was using my other car at the time, and I didn't want to drain the battery unnecessarily. Two days later I went back to the car and the battery was completely dead again!
This time I tested ALL of the fuses in the under dashboard fuse box, as last time I had stopped when I got to the rear light fuse, thinking that was the cause of the problem. None of the fuses caused the current to drop when I removed them.
I tested the current again, twice, and it was still taking 0.3A for exactly one minute, and then going down to 0.01A. I even held the probes on for seven minutes the second time, thinking that maybe the 0.3A draw would reappear after five minutes, but it didn't.
I have now left the battery disconnected, because I can't risk another one being ruined. Has anybody got any ideas what I should try next?
