Many thanks Gas112 for your very helpful advice.Boiler stat is still available at around 25 quid
the broken off phiall can usually be removed by screwing a screw into it and pulling it out use a bit of wd40 sprayed into the pocket
Useful to know and many thanks DP. Have found an engineer who can work on boiler and will ensure annual service now done.Suspect boiler may not have seen proper annual service hence sensor jammed. During said service the heat exchanger, burner etc would be cleaned with a brush, Flue checks and ventilation checked. Entails removing the said phial.
Gas112 knows this boiler better than most
Thanks Kidgreen61. That's excellent news.As above, no reason you shouldn't get another 20yrs out of that boiler.
Consider smart thermostat heads, will reduce fuel consumptionAs above, no reason you shouldn't get another 20yrs out of that boiler.
Very useful tips and looking into these as don't currently have them. Many thanks DP.Consider smart thermostat heads, will reduce fuel consumption
For hot water, fit controls to switch off when water heated to temperature
There are various ways to reduce gas consumption
